Easily View Hardware Information in Ubuntu 10
If you need to know the details of your PC’s hardware, there is a simple graphical application, called GNOME Device Manager, in Ubuntu 10.04 that allows you to view the technical details of your computer’s hardware.
To install the GNOME Device Manager, select Administration | Synaptic Package Manager from the System menu.
Opening the Synaptic Package Manager
If you have never used Synaptic Package Manager before, or if you have de-selected the Show this dialog at startup check box, the Quick Introduction dialog box displays. If you don’t want to see this dialog box again, be sure there is no check mark in the Show this dialog at startup check box. Click Close to continue.
Synaptic Package Manager Quick Introduction
Enter gnome device manager in the Quick search edit box. The results display automatically.
Selecting the GNOME Device Manager for installation
Right-click on gnome-device-manager and select Mark for Installation from the pop-up menu.
Marking gnome-device-manager for installation
A dialog box displays informing you of another package needs to be installed in order to install GNOME Device Manager. Click Mark to mark the extra package for installation.
Marking additional required changes
You’ll notice the libgnome-device-manager0 checked and highlighted in green. It will be installed with gnome-device-manager.
Additional dependency marked
Click the Apply button to apply the changes.
Applying all marked changes
A Summary screen displays showing you the changes to be made. Click Apply to continue with the installation.
Summary of changes to be applied
The progress of the installation displays.
Applying changes
When the installation is finished, a dialog box displays telling you the changes have been applied. Click Close.
Changes applied
Close the Synaptic Package Manager by selecting Quit from the File menu.
Closing the Synaptic Package Manager
To start the GNOME Device Manager, select System Tools | Device Manager from the Applications menu.
Opening the GNOME Device Manager
The GNOME Device Manager main window opens displaying a tree on the left containing entries for all of the hardware in your computer. Select an item in the tree to view a summary of information about the selected piece of hardware on the right side of the window.
To view more details about the hardware, select Device Properties from the View menu.
Viewing Device Properties
The Properties tab displays on the right side of the window.
Properties tab
To close the GNOME Device Manager, select Quit from the File menu.
Closing the GNOME Device Manager
NOTE: The hardware information in the GNOME Device Manager is only viewable. You cannot use the GNOME Device Manager to configure devices. However, sometimes finding out about your hardware is all you need to do and this tool provides a quick and easy method for doing so.
writer: Lori Kaufman
