Amazingly many people still believe that once they delete a file from their computer that the file is lost forever. In truth very rarely is a deleted file lost or unrecoverable. Anyone can easily recover lost files with a few simple tools and the information on this file recovery tutorial. The first step for recovering lost or damaged files is to determine where you want to recover files from. If you last saw your files while downloading digital camera files then you will need to search the card or camera’s storage. If you were transferring data using a USB flash drive then that drive more than likely still holds your files. And, if you simply deleted files from your computers recycle bin, then you will need to search through your computer’s hard drive.
Complete file recovery without touching your computer’s hardware
The next step in our file recovery tutorial is to equip ourselves with software designed to scan digital storage devices and recover lost files. The best program available for this purpose is File Finder. It is inexpensive and will work on any computer.
File Finder differs from most data recovery programs in that it does not require a separate or “technician” computer to be hooked up to the hard drive that hold the missing files. This requires complete dismantling of two computers and is ridiculously impractical.
Rather, File Finder uses a built in Windows shell that allows it to be run directly from any computer’s CD drive and in essence turn the broken computer into the working technician computer. Still let us continue our file recovery tutorial.
File Finder’s included file recovery tutorial makes recovering your files easy
Once you have followed the installation instructions for File Finder and created the special File Finder recovery disk simply load it into the computer you wish to restore files on.
You will be prompted once to load the program and after clicking on load File Finder will appear before you on your screen.
The File Finder Instructions will also automatically load and once these do you will simply follow the steps laid out before you.
File Finder is capable of four different levels of file recovery each more powerful than the next so there is no chance that your specific need cannot be handled.
The instructions are the continuation of this file recovery tutorial and will lead you to successful recovery of lost or damaged files of any kind including documents, emails, photo files, videos and music files. Even compressed files will be located and restored with File Finder.
