Overview of the Personal Computer
While most people are familiar with computer software, others also become familiar with the hardware. Understanding computer hardware can help you understand the capabilities of technology and how the hardware impacts software. The following sections provide an overview of computer hardware and the role it plays with the software that you use everyday.
Keep in mind that this handout is an overview as there are many different types of any single computer component. When you shop for components individually or as part of an entire computer, you will hear lots of acronyms and terminology like Core 2 Duo or SLI. These names come and go as technology evolves. Here we are discussing what the parts of the computer are at a conceptual level.
CPU
The CPU or Central Processing Unit is like the brain of the computer. It is in charge of executing instructions as directed by software programs. The CPU is plugged into the motherboard of the computer, which is explained next. A CPU is roughly a flat square with a lot of short pins sticking out of the bottom. CPU’s get very hot and so must be kept cool with fans inside of the computer.
Motherboard
The motherboard is the main component to which all other computer components are connected. A motherboard is as the name implies a flat board that has many computer chips, slots, and ports on it to allow for communication for data input and output with the devices that you attach to the computer. There are many components on a motherboard including:
Power Supply
As you know, a computer needs power in order to run. Every component of a PC has a power requirement. To meet this requirement we need a power supply that can supply enough power to all of the computer’s components. Power supplies are measured in Watts. This device is a small box shaped device that is screwed into the computer case. From the outside of the case, you plug in the power cord and you can press the power switch. From the inside of the computer case many wires emanate from the power supply. These wires are connected to devices and in several places along the motherboard to ensure that all components’ power requirements are met.
Fans
The computer generates a great deal of heat and it is important to keep the computer cool so that it does not overheat when it is working on an important task for you. There are special cooling systems that some people buy, such as water-cooling systems, but most people are content with having fans in the computer case that keeps everything cool. In older computers the fans can be loud but newer computers have quieter fans. There are 2 main types of fans:
Memory
Memory also known as Random Access Memory or RAM is used by a computer to store data that it is currently using. RAM is very fast, but it needs a constant power supply to hold the information. So once the power is turned off, the memory is erased. Memory looks like a thin, flat rectangle with several computer chips in it. There are special connectors on one of the long side’s of the rectangle that inserted into the memory slot.
Hard Drive
The Hard Disk Drive or HDD is used to store data in a more long-term manner as compared to memory. The operating system and all programs are installed on the hard drive. People often store documents on the hard drive as well. A hard drive is about the size of your hand, but it is rectangular and thicker than your hand. A hard drive uses magnetic platters to store information in binary form, using ones and zeros. The platters rotate at a high speed while a read/write head moves over the platters reading and writing data. The heads never touch the platter, as that would scratch them and destroy the data stored on them since they are spinning so fast. Instead the hard drive is designed so that the read/write head flies just above the surface of the platter. Because of this delicate design, it is possible for the read/write head to touch the platter if a hard drive is moved while it is on. The read/write head retracts to a locks position when the hard drive is not on. There is always at least one hard drive inside of the computer case, but you can have hard drives externally attached to the computer as well.
CD and DVD Drives
CD and DVD drives allow the computer to access files stored on CD and DVD discs. DVD discs store at least 4 times the amount of data as a CD, depending on the type of DVD format being used. You can watch DVD movies using the DVD drive, but you can also use the discs for other data. If you buy a CD or DVD drive that records data, you can write data to these drives. These drives are the same dimensions as a hard drive, and like a hard drive these drives can be internal to the computer case or externally attached to the case through a port such as USB or Firewire. Both drives use lasers to read data from these discs. When a disc is scratched or smudged, it is possible that the laser can’t read the data on a disc properly.
A Word about Static Electricity
Most people think about static electricity when they shock someone after walking across the carpet or when they are folding their laundry. But static electricity is an important consideration when working with PC components. Static electricity or specifically ElectroStatic Discharge (ESD) occurs when a small electric charge builds up and suddenly finds a path to ground and discharges. While this charge is fairly minute to a person, it is enough to damage or even destroy a PC component. When working on the inside of a PC it is vital that you use proper grounding equipment. An example of such items is an anti-static wristband and an anti-static mat. Touching the case does not provide protection for ESD.
