If your CD drive making problem to show COMPACT DISK disk, taking time to read and rendering subject matter there is no disc in the drive. These are the symptoms of unclean or weak CD-drive electron lens, because unclean genus lens can create faults in reading or composing and soon will not work at all.
Just Follow the easy steps to handle and get clean a CD-Drive.
1. First step is make sure your disks are clean, unscratched and you ‘re loaded up it by rights.
2. Always use optical maser lens system cleaner to make clean drive electron lens.
3. Put in the optical maser lens system cleaner disc and then play it for 2 or 3 min.
4. Using CD drive cleaner by rights clean the CD ROM optical maser from dust. If your drive still making some problem then spread out it and clean the lens system with a cotton plant swab.
